postbuilder, manual tool change, outputting a M00 at end.
Hi.
For starters,I am new to postbuilder and VERY new to tcl programming.
I am embarking on the "learn as you go" method of making a post.
I have managed to figure everything out I need to except one simple, but important item.
The post does not output an M00 at the end of an operation that uses a tool flagged as "manual tool change"
How can I get the post to do that??
My instinct says I need to write a custom command that querys the MOM_tool_change_type variable and outputs based on that.
Am I on the right track?
Can someone help me with the syntax to get an "if" statement to work?
JAY
JAY
RE: postbuilder, manual tool change, outputting a M00 at end.
Where are you defining the Manual option?
I set it on the tool.
There is a event marker in Post Builder for a Manual Tool Change and it outputs a M00 at the tool change.
To get a M00 at the end of the operation you will need a custom command.
Create a custom command with the following text and place it at the end of path event in post builder.
global mom_tool_change_type
if { $mom_tool_change_type == "MANUAL" } {MOM_output_literal "M00"}
John Joyce
Tata Technologies iKS
1675 Larimer St.
Denver, CO
www.myigetit.com
John Joyce
1675 Larimer St.
Denver, CO
www.myigetit.com
Thanks for getting me started.
However, this solution alone, does not work.
I have about 10 seperate operations using the manual tool...
The output file has a "M00" at the end of each operation. I only need the output at the end of ALL the ops included in that tool sequence.
How can I achieve that?
J
If the next operation has a tool change...Output M00
If the next operation does NOT have a tool change...Output nothing.
J
try this
global mom_next_oper_has_tool_change
if { $mom_tool_change_type == "MANUAL" && $mom_next_oper_has_tool_change =="YES" } {MOM_output_literal "M00"}
John Joyce
1675 Larimer St.
Denver, CO
www.myigetit.com
