How do I make new screw/parts that have the autosnap when inserting?
You know how when you insert a screw (from sworks library) into an assy and it has a autosnap type feature when you hold the screw next to an object, it will snap into the hole flush with surface? I think you can also do it with toolbox. Anyway, if I draw a new screw or some other fastener, how do I make it have this snap type feature when I insert it into an assembly?
thanks
thanks
RE: How do I make new screw/parts that have the autosnap when inserting?
Dan
www.eltronresearch.com
Dan's Blog
thanks again
