Salt or Calcium Chloride
Structural here needs some help
We have many catwalks, scaffolding, walk ways made from painted steel and/or galvanized steel.
The question has come up - Is it better to de-ice these with salt (don't think so) or calcium chloride?
Or is there a better chemical we should be using??
Hair dryers are not accpetable!!
RE: Salt or Calcium Chloride
David
rmw
http://
The most common salt is calcium chloride because it is has the least problems with freezing. You can also apply it as a liquid. Magnesium chloride is generally applied as liquid.
You will have corrosion problems with all of the salt chemicals. The following link has some information for structural designers:
http://tac-atc.ca/english/pdf/roadandbridge.PDF
1. Use of sand is limited, and without proper sieving - you will ensure that some of the road users will be blessing you for the sand blasting and bigger stones hit effects.
2. Application of the chloride-based salts is effcient, and each can be used in liquid form, to avoid above problem.
3. Application of all of the chloride-based salts is related with the corrosion.
4. Before use, check the efficiency (i.e. in Europe there is common policy, that below 10-15C salts are not effective anymore and only one choice is a sand).
