Load Factors for WS Pipe pressures
I am designing a 10'deep x 10' x60' concrete trench housing a water supply pipe at a pump station. The trench need not meet watertightness requirement. Is the load combination of
(1.4 D + 1.4 F) per ACI 318-08 sufficient for designing the trench walls for lateral thrust from the pipe pressure? (This is the test pressure specified for the pipe).
RE: Load Factors for WS Pipe pressures
civilperson - to clarify, since I may not have explained well the conditions of the pipe.
I was told by the process/mechanical engineer that the wall would be subject to the pipe internal pressure.
The far end of the pipe in the trench is a dead or capped end, while the joint where the pipe exits the trench is a special flange (referred to on the mechanical drawings as a harness). I can see where the reaction of the pipe pressure against the capped end should be resisted by the wall unless there was some other anchored element to resist it. Does this help?
