High Pressure Valve Ratings
Dear,
What will be thickness of the flanges using for high pressure rating valve of 5000#, 10000# etc.
How we calculate the blind thicness and clamping force required for the all ratings valve with different sizes.
Thankss.........
RE: High Pressure Valve Ratings
Thanks seagull,
I found that higher rating valve is there but below 2" size, I want to calculate the flange thickness for the higher ratings flange.
jaff
