joint properties
joint properties
Hi
How can i adjust joint properties? For example if I have to steel beam and they are welded together how I can specify this property to program?
RE: joint properties
There you may find conditions for continuos, hinged etc.
Again, one may model everything 3D with the constraints etc. This is required at some shops but not usually in the structural world where even the codes are geared for a different practicality. Nor the scale of structures nor its spread nor the computer capacities of now, nor to say that of training, support to practice otherwise.
