Natural Frequency of a pinned-pinned beam
Somewhere in my math i am a factor of 10 off for my natural frequency for a beam. What is the equation for the natural frequency of a pinned-pinned beam. Thanks
RE: Natural Frequency of a pinned-pinned beam
L = span
m - mass of beam
EI - EI of beam
N = node number (1, 2, 3, )
ω = natural frequency
Π = Pi
ω = (N2Π2 / L2) x √(EI / m)
If it is uniform pinned pinned then f1=1/2/pi*(96*E*I/M/L^3) where M is total mass of beam.
Cheers
Greg Locock
SIG:Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
Calculate the deflection at midspan of the beam due to the uniform load corresponding to the uniform mass. Call this Delta.
Then fn = 0.18*sqrt(g/Delta)
This gives fn in Hz. Using USC units, g = 386 in./sec.^2 and Delta is in in.
THis equations actually works pretty well for all kinds of situations. For example, you can check the lateral period of a building using it and get pretty close to what your computer program should compute.
Cheers
Greg Locock
Check that mass vs weight is not confused. In English units, check if a g-c term is required for lbm/ lbf conversion. Foot (length) vs. inches (E, I) could be another source of problems.
Cheers
Greg Locock
In some ways, I'm conflicted about its use because it misleads folks who aren't vibe specialists.
An example:
I was giving a seminar on floor vibrations several years ago and calculated fn for a composite beam (steel beam with concrete slab) and someone asked the question "What loads go into w for calculating Delta? Precomposite DL, that plus superimposed DL, etc.?" Representing the mass as a "load" really threw him off.
He never would've gotten confused if we were using the form with "m" instead.
