Assemblies Containing Adjustable Parts
Hello-
I'm a newbie in Solid Edge and I have run into a problem working with assemblies that contain adjustable parts.
I've created an assembly of a frame that is mostly made up of identical angle iron of multiple lengths. I made this angle iron component an adjustable part with length as the adjustable variable.
The angle iron portion of the assembly works great, but now that I want to assemble additional brackets (rigid parts) to the angle iron I get the message "The requested relationship conflicts with others and cannot be placed".
Is it not possible to constrain rigid parts to an adjustable part within the same assembly? I've found that if I add the frame as a subassembly I can assemble rigid parts to those same faces, but I would like to those parts to exist within the frame assembly.
Sorry about the long-winded post and thanks in advance for any responses.
Bill
Bill
RE: Assemblies Containing Adjustable Parts
However, in the assembly you can create planes or co-otdinate systems relative to the adjustable part and then constrain onto those.
bc.
2.4GHz Core2 Quad, 4GB RAM,
Quadro FX4600.
Thanks again!
Bill
I just noticed today that the post had no replies so thought I'd take a look.
bc.
Quadro FX4600.
