linking fortran and abaqus: cannot open file 'MSVCRT.LIB'
Dear Friends
I am trying to work with user subroutines in abaqus and I have this error in the text file now.
"Abaqus JOB job-1
Abaqus Version 6.7-1
Begin Compiling Abaqus/Standard User Subroutines
12/3/2008 10:32:01 AM
End Compiling Abaqus/Standard User Subroutines
12/3/2008 10:32:02 AM
Begin Linking Abaqus/Standard User Subroutines
LINK : fatal error LNK1104: cannot open file 'MSVCRT.LIB'
Abaqus Error: Problem during linking - Abaqus/Standard User Subroutines.
This error may be due to a mismatch in the Abaqus user subroutine arguments.
These arguments sometimes change from release to release, so user subroutines
used with a previous version of Abaqus may need to be adjusted.
Abaqus/Analysis exited with errors"
Do you have any idea about how to solve this error?
regards
"Abaqus JOB job-1
regards
RE: linking fortran and abaqus: cannot open file 'MSVCRT.LIB'
If the correct version of compilers are installed, then you have to make sure that the paths to various library files are defined correctly.
You can verify the intallation running the following command on command prompt:
abaqus verify -user_std
Best.
1. Open your Abaqus site environment file, which is typically found at C:\ABAQUS\(version)\site\abaqus_v6.env
2. Look for a line that begins with link_sl
3. In that line, change the text
/DEFAULTLIB:MSVCRT.LIB
to
/NODEFAULTLIB:MSVCRT.LIB
