Random vibration units
I normally input my random vibration units into my controller as g2/Hz.  Sadly I have been given a specification quoting an ASD of 1.92m2/s3
Does anyone know how I can convert m2/s3 to g2/Hz.
RE: Random vibration units
The dimensions are compatible.  Is there not just a factor of (9.81)^2 to either multiply or divide by?
- Steve
 I remember doing this ages ago but was not too sure.  Thanks for the prompt response I can now run my test today,
Thanks again.
... beware of peak-peak, peak, RMS differences too.  Always a killer and best to understand before trusting and using these numbers.
- Steve
Ahhhh.....  Could you explain a bit of what you mean by this to me.  I am worried that I miss something that is fundamental and wrong basically.
Sine wave: x=a*cos(2.pi.w.t)
Peak = a
Peak-Peak=2.a
RMS=a/sqrt(2)
If you are using a calibrator, it'll probbaly be set to a dB(RMS) acceleration value.  That would be an RMS value divided by a reference RMS value, then logged, etc.
In my days working in this area, I never trusted any piece of vibration measurement equipment that didn't output instantaneous m/s2, which I could then mangle however I chose.
- Steve
Thanks, I am with you now.... I think.
Your assistance and advice is greatly appreciated.  Thanks for your time.  This is a great site because you guys put in so much effort to help.
Thanks again.
