apply global material to child parts in assembly
is this possible? I don't need this for drawing callouts, but would like it for mass properties.
there is a slick tool in solid edge to do something like this.
RE: apply global material to child parts in assembly
Can you explain a little better where "material" is located? RMB?
Mango,
Thanks for the help, but i am in fact asking about solidworks. I have some previous experience with solidedge, which i didn't like very much but recognize its strength and that tool was one of them.
There may be a specific tool buried somewhere in SW, but if there is I don't know about it. The above method is the only way I know to change materials en masse.
A macro for this could probably be developed to eliminate the need for graphical selection.
Go into Tools>Options>System Options and in FeatureManager "tab" make sure that Material is being shown in the drop-down menu. Make sure all your Lightweight parts are Resolved. Material Properties for your parts should be visible in your Feature Manager (FM) tree, as an icon that looks like a stop light, but with red/blue/green lights with horizontal lines by each.
I don't think there is a way to Ctrl-select various parts in the FM and do a global material change, you will have to change each individual part. With the top assembly open, click a part, click the Edit Part icon and after the part details in the FM are highlighted blue (default color) you can select the Edit Material option.
arlenn,
And you can download more materials....
(links below)
Chris
SolidWorks/PDMWorks 08 3.1
AutoCAD 08
ctopher's home (updated Aug 5, 2008)
ctopher's blog
SolidWorks Legion
