Aluminum Roughness
Aluminum Roughness
Aluminum Roughness
What is the relative roughness for Aluminum?
I'm working on a fluids heat exchange project.
RE: Aluminum Roughness
Absolute roughness, typical value for aluminium 0.0015mm
Ugh.  Wouldn't it depend on the finish, which depends on the process used (sand casting vs. extrusion vs. machined and polished, for examples).
thanks geordie87.
Since it is a fluids heat exchange project I was assuming stadard tubes for a shell and tube heat exchanger
