Conveyor belt speed reduction
I need to calculate the pulley diameter to reduce the conveyor belt speed to 40m/min. It has been a long time since I worked with the calculations.
Description of set-up: Motor running at 1470rpm transmits power from a 145mm pulley to a larger pulley of diameter 630mm. from here a gearbox with a speed ratio of 13:1 transmits power to the conveyor pulley. Finally belt speed is read off instrumentation as 48m/min.
Please could someone help with the formulae and pulley diameter one needs to use?
Set-up attached:
Set-up attached:
RE: Conveyor belt speed reduction
-handleman, CSWP (The new, easy test)
Alternatively change the motor pulley to 120mm
(40/48 x 145=120.8 mm)
Ross
