Flanged connection
Flanged connection
Flanged connection
in a flanged connection with bolts made between two flanges of different material, the first with modulus E1, the second with E2, how I can calculate the load of each bolt? Is there any reference or calculation method regarding this issue?
Thank you for the help.
RE: Flanged connection
A journal article:
J Eng Gas Turb & Power 127, 2 (2005) 240-248 Unique Challenges for Bolted Joint Design in High-Bypass Turbofan Engines
available here:
http://scitation.aip.org/getabs/servlet/GetabsServlet?prog=normal&id=JETPEZ000127000002000240000001&idtype=cvips&gifs=yes
Some others:
http://www.offshore-support.de/Papers/Failure_analysis_of_bolted_steel_flanges.pdf
ftp://www.stahlbau.uni-hannover.de/Publizierungen/Wiesbaden_Schaumann-Kleineidam-Ring-Flange.pdf
A software program that does it:
http://www.hexagon.de/sr1_e.htm
Cory
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips Fora.
