Batch print and export
Does anyone know a good way to...
1) Batch print solidworks drawings
2) Batch export from SolidWorks to eDrawings
For example, say I have a directory full of solidworks files, is there a way to batch print and export those? Alternatively, say I have a load of files open inside SolidWorks, is there a way to batch print and export?
Cheers, Tim
RE: Batch print and export
Which version of SW do you have?
The SolidWorks Task Scheduler is included with the Professional and Premium versions.
cheers
Thanks for all the responses guys. We have SW Premium 2007 but I've never come across Task Scheduler. I'll have a look.
Tim
The problem with any automatic method is that none (so far) account for differences in printer settings between drawings.  If you save a PDF, it changes the print settings and will print as garbage on a physical printer if you are tring to print to fit or have a different paper size.
Matt Lorono
CAD Engineer/ECN Analyst
Silicon Valley, CA
Lorono's SolidWorks Resources
Co-moderator of Solidworks Yahoo! Group
and Mechnical.Engineering Yahoo! Group
