Autoclave Beginner - need suggestions
Our company has purchased a 48" x 20' autoclave to cure extruded rubber shapes.  I am looking for some good information (book or article) on the setup of an autoclave, controls, and safety.
Steve
RE: Autoclave Beginner - need suggestions
If it is a standard, off shelf autoclave, the set-up and controls are detailed in the little booklet attached to the guarantee sheet, together with the list of your nearest repair shop.
Otherwise, you might have to disclose to this forum the make and model of your autoclave, if you are really expecting some advice.
Cheers,
gr2vessels
Or maybe even contact the manufacturer.
Mike
Don't open the door when it is under pressure :)
