Thumbnails Aren't Showing Correctly
I'm using Solidowrks 2009 1.0 X64 now and for some reason in windows explorer my thumbnail actaully use the "icon" images. Meaning, I see an image of the part, but I can hardly make out what it is. What happened to my regular thumbnails? Can I fix this?
Joel C. Warnke
Mechanical Designer &
Infrastructure Technician
Integrity Design & Mfg. Inc.
www.integritydesignmfg.com
Solidworks x64 2008 SP5.0
Windows XP Professional x64
Nvidia Quadro FX 3700 512mb GPU
AMD Athlon X2 FX 6400+ CPU
4GB Corsair pc2-6400 DDR2 800mhz RAM
WD Velociraptor 10,000rpm SATA HD
Motherboard M2N-SLI
GPU OC (2
RE: Thumbnails Aren't Showing Correctly
-handleman, CSWP (The new, easy test)
(jg00000's post is third from the last dated 6 Nov 08 18:49)
Flores
If you are meaning how the thumbnail quality is worse than it used to be, Anna's link has the answer. Not really any solution, just an reason why they're crappy.
