A/D Converters
A/D Converters
Are the propagation type A/D Converters subject to design as a hole
or a part of a, say, pipelined converter?
In fact they have, for a n bit resolution, n comparators.
RE: A/D Converters
If you are describing the flash converters for n bit resolution we will need 2*n comparators. The pipelined A/D only needs n comparators for n bit resolutions because it uses a different conversion scheme.
I hope I've been of some help.
