Piping material for Sea water service for Foam pipelines
As per NFPA 11 Galvanised CS pipe is acceptable for sea water service for foam piping on the fire protection system.
I have a feeling that galvanised is not a good choice because for a site installation galvanisation will be damaged and start rapid corrosion for CS pipe.
We are planning to use GRP ( Bondstarand ) pipe for tank foam piping. Will this be acceptable to NFPA code
Any comments will be appriaciated.
RE: Piping material for Sea water service for Foam pipelines
Steve Jones
http://www.linkedin.com/pub/8/83b/b04
