VAWT Flat plane formula
Since I'm new here, and I'm new with aerodynamics,
I am opening a new topic because I can't find something simular on the forum.
The whole problem is started by city regulations because they don't allow horizontal windmills.
So I started trying to calculate VAWT's. And I know something about programming... but not from Aerodynamics.
Problem: a flat plane, under an angle with the wind, moving in any possible angle.
I found the drag and lift formula, a formula to calculate Cd and Cl under different angles, so now I can calculate the force when it's standing stil.
But I need to know the force (and the power) when it's moving... in any direction.
I found several things about horizontal windmills, but I'm always getting stuck when I trie to reduce the formula from rotating to a flat plane with straight movement.
So it would help if someone could point me a direction
(formula, document...)
Greetings
EddyVl
