Earthing of equipment
In electrical maintenance field there is a practise to measure Earth resistance of earth pit on periodic interval.
Is there any method to check/confirm the continuity of the earth conductor between earth pit (grid) to the equipments
Generally population of the electrical equipments are too large in industry,in that case what will be the pratical method.
RE: Earthing of equipment
The high-current method of testing ground grid continuity and connections is a reliable, accurate method
of detecting faults in the ground system. Some one do it by means of parallel connected welding transformer in order to achieve 300-1000 A and a measuring accuracy.
See-as example:
http://www.hccontrol.co.za/Search/Suppliers/Megger/grndResTestEquip/Datasheet/GTS300_DS_en_V10.pdf
or see:
http://www.mittoninstruments.com/docs/Practical%20Testing%20of%20Grounding%20Systems.pdf
Dear 7anoter4,
Thanks for guidance but as you well aware the earthing grid acroos the plant (industry)passing thr several steel structure and if we adopt current injection method, practically it's not possible.
If any other way to test it, let us know.
Check clamp-on resistance meter at AEMC website.  They have some technical info on the principles and suitability of this method.
