Rock blasting
Rock blasting
Hello
Can any one guide on some basic materials on rock blasting
Thanks alot
Thanks alot
RE: Rock blasting
<<A good friend will bail you out of jail, but a true friend
will be sitting beside you saying " Damn that was fun!" - Unknown>>
RE: Rock blasting
The other pearl of wisdom is you dont learn anything from the sucessfull blasts..... you only learn from the ones you screw up..... and on that basis, I'm now an expert!!!!
RE: Rock blasting
http://www.powells.com/biblio?isbn=9781892396006
It contains good general information, but as miningman says, don't try doing this based solely on "book learning".
www.SlideRuleEra.net![[idea] idea](https://www.tipmaster.com/images/idea.gif)
www.VacuumTubeEra.net
RE: Rock blasting
RE: Rock blasting
The US Bureau of Mines has conducted tests on what it takes to cause building damage and that has been published. They also may have some guidance publications.
There are numerous requirements on how to handle and transport the stuff.
My guess is that, unless you need this for your projects, etc. it won't be worth the trouble.
RE: Rock blasting
RE: Rock blasting
Can you give me the link of that manual. I couldnot find it.
oldestguy :"The US Bureau of Mines has conducted tests on what it takes to cause building damage and that has been published" do you have the link or the name of the published materials so that I can order it.?
RE: Rock blasting
Publication Number: EM 1110-2-3800
Title: Engineering and Design - Systematic Drilling and Blasting for Surface Excavations
ht
RE: Rock blasting
RE: Rock blasting
RE: Rock blasting
Also I could not find the link .
Can you plesae advise how can I get the guide.
Thanks alot
RE: Rock blasting
http://www.austinpowder.com/blasterzone/index.html
RE: Rock blasting
