Difference between Joint efficiency and quality factor
When we calculate required minimum thickness, we use E value which ranges around 0.5 to 1. In some formula, it is called joint efficiency, other formula refers it quality factor. What is the conceptual difference? Could anyone explain?
kyong
kyong
RE: Difference between Joint efficiency and quality factor
prex
motori@xcalcsREMOVE.com
http://www.xcalcs.com
Online tools for structural design
"Quality factor" applies to castings and as stated above conceptually works the same way (welds are castings after all). Interestingly it does not apply to GRAY CAST IRON. The more/higher level of inspection done to verify freedom from harmful flaws, the higher the allowable stress value for calculation of thickness or strength.
The conceptual diffrenece between the 'quality factor' and 'weld efficiency' is explained by Prex and rustbuster1.
In cases of calculations of casting welded joints, both the 'quality factor' of casting and 'weld efficiency' factors are involved. In such cases, as per ASME Sec VIII Div I Clause UG-24, the lesser of the two is to be applied but not both.
Hope this will help.
There is not way to change a 100% radiographic examination in asme div2 for a steel casting?....that mean... for any casting a 100% Radiographic apply?....
