Export Configs as Individual P/N's
Happy Turkey Day to all :)
I did a search on the forum but did not find anything addressing this question so here goes.
I have a part that has about 10 configurations that were created from a DT.  Now that they have been created can I save each one as an individual part number and delete the configurations?  Maybe a batch export?  Or was there a better way to do it from the beginning as I knew I will need them as individual P/N's?  Each one will also need some custom properties associated as well.
Thanks for any suggestions.
BB
RE: Export Configs as Individual P/N's
Sorry forgot to add that I am on SW2008 sp4.0
BB
Although many people disapprove, individual part numbers [u]can[/b] be used (the same as any other properties) within the Configuration Specific properties (unless you're using PDMWorks).
Try the ConfigRipper macro from http://sw.fcsuper.com/index.php
cheers
Hi CBL,
I will give it a try, thanks very much for your input.
BB
I haven't used the macro mentioned above but I have used
"SaveConfigurations.swp" from http://www.cadimensions.com/Resources/macros.cfm
It doesn't give you the option to name each config, rather it automatically saves the configs and appends the config name to the model name.
Flores
