Breaking the Instance (copy/Paste)
People.
Nx 4.0.4.2.MP6
have copied and pasted a number of Features... I checked the 'instance of original' during the paste but now find I need to adjust the geometry of only one
? - is it possible to break the 'instance' making the feature unique that I can then adjust ...
regards .... gary
RE: Breaking the Instance (copy/Paste)
Depending on the type of edit, I would look at the Direct Modeling tools at...
Insert -> Direct Modeling ->...
...where you can edit the topology (geometry) of the model overriding the features.  For example you can use 'Resize Face' to change the size of a Hole or a Boss.  'Reblend Face' to edit the size of an Edge Blend.  'Move Region' to change the size of something by moving a face.  'Simplify' for removing faces, like deleting a Hole or removing a Blend.
Anyway, take a look at the documentation for Direct Modeling.  There should be some examples there of what you can do using this tool.
John R. Baker, P.E.
Product 'Evangelist'
NX Design
Siemens PLM Software Inc.
Cypress, CA
http://www.siemens.com/plm
