HSS VERTICAL BRACE CONNECTION
Can anybody help me find example for "tee" connection on HSS columns? How you design "tee" under reversible axial load?
RE: HSS VERTICAL BRACE CONNECTION
I would assume using K2 in black book would be applicable. You'll have to check the limits of applicability to make sure your step isn't too much.
