valve for chlorine water
We have the job to design a valve for chlorine water (for an offer), but we have no real experience in doing this. The customer would like to have alloy 59 or inconel 625. But the machining time and the material costs are very high. Maybe there is a cheaper solution or material according to the needs specified in the attachement. Thank you for help.
RE: valve for chlorine water
<<A good friend will bail you out of jail, but a true friend
will be sitting beside you saying " Damn that was fun!" - Unknown>>
You should be able to find someone closer, this is not too specialized of an application, I don't think
Can you post a URL to their company website where I can make contact?
Thank you
1. Try to repost at valve engineering forum to get a broader feedback.
2. Try for instance : Metso www.metsoautomation.com
(worldwide) Ballvalves or possibly butterflyvalves (BFL normally limited to pressure classes about 40 bar - but might exist for higher)
3. Stainless steel valve US www.stainlessvalve.com O-port valve.
Comment: None of the two suggested will give you cheap solutions, caused by the combination of fluid, temperature and size.
Before final design I would ask your customer/enduser, after I had done a brief market research, if he could adapt by going down in pressure design to PN40 or down in design temperature, or up in flow/down in size to get acess to a broader aspect of already commercially available produced and existing valve designs.
In addition and as mentioned by others: there is a broad availability of designers and producers of special valves, depending on where you are located.
Plastech Piping and Fabrication Inc
3450 91 Street NW, Edmonton, AB T6E 5R1
Telephone : 780-490-5565
