Joint forces in multispan cylindrical shell
hi
i m designing the multibay cylindrical shell with chord with 35 feet and span of 72 ft.
i m designing it by template of cylindrical shell.
at joint i got the forces in all direction, horizontal forces are quite large as compared to vertical force. I m supporting the shell on 24" x24" column and height is 38 ft.
i got vertical force 45kip and horizontal force 120 kip i.e. thrust from valley beam or end of shell.
how i should design the column, should i take moment by horizontal force i.e. 120x38 or something else.
i want suggestion for column design.
thanks
