Tools>Options>file Locations>Reference Documents
Can anybody name any negative consequences to a multiple user set up relying on PDMWorkgroups and a Routing Library location not in PDM if the Routing Library is not in Referenced Documents area?
Joe Hasik, CSWP/SMTL
SW 08 x64, SP 4.0
SW 09 x64, SP 0.0
Dell T3400
Intel Core2 Quad
Q6700 2.66 GHz
3.93 GB RAM
NVIDIA Quadro FX 4600
RE: Tools>Options>file Locations>Reference Documents
Joe,
I'm not understanding your question.
We don't use the Reference Documents in the options area. We have all our parts pathed though the Design Library that is linked in PDM Workgroup.
Colin Fitzpatrick (aka Macduff)
Mechanical Designer
Solidworks 2008 SP 4.0
Dell 490 XP Pro SP 2
Xeon CPU 3.00 GHz 3.00 GB of RAM
nVida Quadro FX 3450 512 MB
3D Connexion-SpaceExplorer
You know Colin, I didn't add anything to this list either, Solidworks did it for me behind my back. Do you have any libraries that aren't allowed to check into PDM or are you running absolutely all of your parts through the vault?
SW 08 x64, SP 4.0
SW 09 x64, SP 0.0
Dell T3400
Intel Core2 Quad
Q6700 2.66 GHz
3.93 GB RAM
All our stardard part libraries are not checked into PDM and linked through toolbox. They're the parts we use that are not revision controlled like screws, electrical connectors etc...When drag and dropped from the design library into and assembly, they display a toolbox icon in the tree just like a SW toolbox part. Sometimes users sneak in stardard parts into PDM, and I have them pull the assembly from the vault, and add the part to our design library, then refile back into the vault.
Mechanical Designer
