Etabs: Model Check Meshing Warning
Has anyone experienced this kind of warning under etabs "Model Ckeck" piror to analysis?
Warning: Checking meshing, At33.8MPD area F1232 (99.91% Increment)
Warning: Checking meshing, At33.8MPD area F2240 (3.53% Reduction)
Actially, i am using membrane elements in modelling the floor slab. Due to irregular framing plan, my slab is in irregula shape.
Will it be a reason leading to these warnings?
Is there anyone who has experience in resolving these warnings?
Many thanks.
Many thanks.
RE: Etabs: Model Check Meshing Warning
Also since you are modeling as membrane element, it may cause of this.
Why are you defining slab as membrane, you dont have any out of plane load??
Good luck!!
