Fire Damaged Steel
Fire Damaged Steel
We have a building under construction that was recently damaged by a fire. Please provide any references or comments on how to correlate paint burnoff, discoloration, rust, deformation, etc., to actual damage of erected steel members.
RE: Fire Damaged Steel
http://fi
http://fil
h
Even if the steel is OK, check connections,particularly if any steel is connected to concrete. The expansion of the steel members will often spall the concrete around connections.
This free DOT manual has been very helpful in the past.
htt
h
www.SlideRuleEra.net![[idea] idea](https://www.tipmaster.com/images/idea.gif)
www.VacuumTubeEra.net
