*vmask and /noerase problem
I need to plot 7 curves per one graph in ansys and in the same time to use a *vmask command for each curve. So I wrote:
*DO,R1,1,P_1
*DO,R2,1,P_2
*DO,R3,1,P_3
*DO,T0,1,10001
/GOPR
TAB_4(T0,R1)=TAB_3((T0-1)*0.01,1)
*IF,TAB_4((T0-1)*0.01,R1),LE,PO_3(R1,R2,R3,1,PO_2(R1,R2,R3)),THEN
MASK(T0,R1)=1.0
*ELSEIF,TAB_4((T0-1)*0.01,R1),GT,PO_3(R1,R2,R3,1,PO_2(R1,R2,R3))
MASK(T0,R1)=-1.0
*ENDIF
*ENDDO
*ENDDO
*VMASK,MASK(1,1)
*VPLOT,TAB_4(1,0),TAB_4(1,1),2,3,4,5,6,7
it works OK, but I realized that only the first column of MASK was used. I decided to try a trick which was adviced me on this forum some time ago a I rewrote my code to:
*DO,R1,1,P_1
*DO,R2,1,P_2
*DO,R3,1,P_3
*DO,T0,1,10001
/GOPR
MASK(T0,R1)=1.0
MASK(T0,R1)=-1.0
*ENDIF
*ENDDO
*ENDDO
/ERASE
/REPLOT
/NOERASE
/REPLOT
*DO,T0,1,7
*VMASK,MASK(1,T0)
*VPLOT,TAB_4(1,0),TAB_4(1,T0)
*ENDDO
... but then obtained an error message like this:
TAB_4 is dimensioned as 10001x7 but the second subscript requested is 10001 ...
*DO,R1,1,P_1
*DO,R2,1,P_2
*DO,R3,1,P_3
*DO,T0,1,10001
/GOPR
MASK(T0,R1)=1.0
MASK(T0,R1)=-1.0
*ENDIF
*ENDDO
*ENDDO
*VMASK,MASK(1,1)
*DO,R1,1,P_1
*DO,R2,1,P_2
*DO,R3,1,P_3
*DO,T0,1,10001
/GOPR
MASK(T0,R1)=1.0
MASK(T0,R1)=-1.0
*ENDIF
*ENDDO
*ENDDO
/ERASE
/REPLOT
/NOERASE
/REPLOT
*DO,T0,1,7
*VMASK,MASK(1,T0)
*ENDDO
