Accelerometer response
In what form is the accelerometer responds during random vibration? Or in other words, how does the response plot looks like? Is it in g vs Hz or g^2/Hz vs Hz or g vs  time? A known PSD profile is input and the area under the plot is G rms.
Thanks.
RE: Accelerometer response
Whatever are you talking about?
An accelerometer measures acceleration, hence, its output is acceleration, usually in mV/g.
PSDs are processed from the raw data.
TTFN
Thanks a bunch. I know that accelerometer gives data in volts/g. But I would like to know how the PSD is derived from the raw data. Do I have to know the resonant frequency of the system? And do I have to know the transmissibility? Please explain.
No. I am trying to understand the process because I have never done a vibration test analysis before. Please help.
The response plot will look like whatever you inputed, so if you used g^2/Hz, then that's what you will get out.  If you happen to have a resonance at 1000Hz, then there will be a spike at that frequency in g^2/Hz.
To be a bit more specific than IRstuff, you need to review Fourier transforms, and then discrete Fourier transforms.  These transform time-based data functions (or series of discrete time-based data points) into frequency space.
A PSD producing program takes in acceleration (vs. time) in g's and produces a plot with units of g^2/hz on the vertical axis and frequency on the horizontal axis.  That plot tells you where the energy of the signal is.  If there is a peak near 10 hertz then you might have a resonance near that frequency (or just a lot of activity near 10 hertz for a reason other than resonance).  The sharpness of the peak gives an indication of the damping at that frequency.
I don't disagree, IR - but somebody else may stumble on these posts and wonder...
