IBC-Structures definition-Pipe Truss
I am designing a pipe truss. The person checking my calculations wants to check a loading combination of 0.6 DL+WL as per IBC. My question is does IBC apply to pipe truss. The checker thinks that pipe struss is a structure. There is no definition of structure in IBC. I feel that process industry practices(PIP) does not have this loading combination. The loading combination is only DL+WL as per PIP. Any comments pl.
RE: IBC-Structures definition-Pipe Truss
If the truss is not subject to wind forces, then the load combo does not apply. Otherwise, use it as suggested.
Mike McCann
MMC Engineering
If you have a pipe truss and it is exposed to wind, then as an engineer you would want to use at least a 1.5 SF against overturning in your design.
The original D+/-W combo that you cite still used a 1.5 SF. The 0.6D +/- W just codified it into a load combination.
I guess I do not understand the difference here - dead load is always there - never, but never changes. It is the live load that varies, such as wind, earthquake, personnel, equipment, furniture, etc.
What are you getting at here?
Mike McCann
MMC Engineering
However, as JAE said, the 0.6DL is meant to provide a minimum safety factor without actually introducing safety factors into the equations.
