What does it do?
What does it do?
What does it do?
What does an old G&W oil filled switch do, and how does it work?
RE: What does it do?
It is a switch, how much more basic do you need?  It works by interrupting the circuit through the switch, just like any other switch.
The contacts are (supposed to be) submerged in oil, which helps extinguish the arc. Make sure there's oil in it before you operate it!
