Simulation or Source -
When using a signal generator to simulate a measured variable what is the difference in injecting mA using a source function and injecting mA using a simulation function ??
RE: Simulation or Source -
Then again, there is very often a possibility to adjust the parallel resistor in the source or simulated injection mechanism. They are the same thing - at least to me.
Gunnar Englund
www.gke.org
Source = imitate a 4-wire transmitter
Simulate = imitate a 2-wire transmitter
Gunnar Englund
www.gke.org
Roy
