Drift and sliding snow loads on sloped roofs
I am just curious if we need to consider drift and sliding snow loads on lower sloped roof beside another higher sloped roof.
For example, I have two roofs w/ 12:12(low) & 8:12(high) as below:
           '         8:12  'Ridge
 12:12       \             '
   Ridge       /           '
Do I need to consider drfit load (and sliding snow loads) on the lower roof? If so, is it a little bit smaller than what specified in ASCE7?
RE: Drift and sliding snow loads on sloped roofs
oops. the drawing messed up. the two ridges shoud be in 90 degree angles.
