VB + C INTEGRATION
VB + C INTEGRATION
How can i integrate the programming languages.For example i have a subroutine in c program and want to add it to my VB program. I want a but to call the c-subroutine and return the values to the VB program. Can this be done ? how ?
RE: VB + C INTEGRATION
To call code written in one programming language from code written in another programming language, you have to know the following things:
1. How does each language lay out their stack? This one is REAL important. The stack is where many languages -- C is one of them -- look for:
a. variables that are passed to the subroutine
b. the return address in the calling program
2. Who is responsible for cleaning up the stack
3. How big are those variables on the stack? What is the bit order of each variable?
There are easier ways to solve this problem. Writing a file is one of them. Using pipes is another if your operating system supports pipes.
-Kevin
1) two text boxes in VB for input
2) a button
3) a picture box to diplay output
4) a subroutine in c that takes in two number adds them a gives back a resulting variable.
Now how do i make the button pass the values from the text boxes to the subroutine and get the result variable to be displayed back in the picture box.
I want to know this becoz i have huge matrix calculation in C and its very cumbersome to re-write them in VB. Hope u have a solution for this. Thanx once again.
alpesh
commands ) you can write file SHELL to the C progran which
writes the result to a file which the C can read.
<nbucska@pcperipherals.com>
