Corrosion Allowance in Splash Zone
I have to design a clamp system in the splash zone of a platfrom. The clamps are coated with 1.5 - 3 mm of epoxy coating.
Do I have to consider the corrosion allowance in the design?
Wath is the amount of corrosion per year and wath are the reference standards?
Thanks.
Thanks.
RE: Corrosion Allowance in Splash Zone
Steve Jones
http://www.linkedin.com/pub/8/83b/b04
This depends on the design life of your clamps. Your epoxy coating may not last longer than 5 years without maintenance...
In the preliminary design i selected 5mm of corrosion allowance. Is this value acceptable?
normally you find that value.
Eric
Steve Jones
Its the type and thickness of coating on the clamp for the splash zone that you need to consider.
"Pumping accounts for 20% of the world's energy used by electric motors and 25-50% of the total electrical energy usage in certain industrial facilities."-DOE statistic (Note: Make that 99% for pipeline companies) http://virtualpipeline.spaces.live.com/
1 with brace welded on the platform leg and
1 clamped on platform leg with neoprene as internal protection coating.
The client considered this section of riser not cathodically protected and suggested a corrosion allowance of 5 mm to be considered in the design.
Is this a reliable approach?
Deepray, as you can see, its a pretty common criteria.
