Turn OFF the sticky hand?????
This sticky modification hand is killing me.  When I try to modifiy a complex part (in part mode), the hand grabs line entities/edges and anything else but the dimension and drags it....sometimes I don't notice that this has happened.  My last sheet metal parts from the vendor were incorrect because of this problem.
How do you turn this unhelpful hand off?
zjjason
RE: Turn OFF the sticky hand?????
A little late but here it is:
In build 2002180 and above there's an undocumented config.pro option called
sketcher_3d_drag    no
that disables "mouse-dragging".
Jan A
Rand Worldwide
