is it possible export thermal matrix
I'm relatively new to Abaqus and therefore don't know all it's functions and capabilities. I am doing a transient thermal analysis and I need to export the thermal equivalent of the mass and stiffness matrix for use in another solver.
However I wasnt able to export these matrices and I'm not sure wether it's possible at all. I tried to use the MATRIX GENERATE command, but hadn't had any luck so far. I can only get it to work with structural analysis.
Is there a way to export the matrices also for transient thermal problems? If so, how can I do it? It would be great if someone could give me some help on this!
Thanks a lot
