Fan Efficiency
Fan Efficiency
Hi
For one of the fired heaters ID fan , the licensor spec clearly says the fan blades shall be of Radial type only. One of the vendor has offered an ID fan of DWDI configuration with efficieny of 30% during normal condition and 50% for design flow conditions. Vendor has indicated that if it is Backward curved blades design you can expect an efficieny of 50% for normal flow conditions. I stress upon the vendor that he has selected a bigger fan and that is only the efficiency is very less during normal flow conditions .I would like to know , what will be the acceptable efficiency of the Radial fans . What can be the acceptable difference between the Design flow and Normal flow conditions for any type of fan.
RE: Fan Efficiency
Cheers
Greg Locock
SIG:Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
RE: Fan Efficiency
