API-650 11th Ed, Add 1 - Table 5-1b
Paragraph 5.3.5 states that when 6mm plate is specified, then 0.236 inch plate can be used with US Customary units.  But does this mean the 1/4 inch values that used to be in Table 5-1b must change to 0.236?  All the other values are standard US thicknesses.  But 0.236 in this table?  Could this be a misprint?
Richard Ay
COADE, Inc.
RE: API-650 11th Ed, Add 1 - Table 5-1b
In the earlier draft versions of this document, it was 1/4".  I believe it should be 1/4".  My opinion only.
Dude, It's simply allowing 1/4inch and 6mm plate to be used interchangeably.  Ditto for 3/16" and 5mm plate.
Joe Tank
Actual conversions (1" = 25,4 mm)
1/16" = 1,5875 mm
1/8"  = 3,175 mm
3/16" = 4,77 mm
1/4"  = 6,35 mm
1/2" = 12,7mm
So the "in-the-head" conversion values (1/16" = 1,5mm thus 1/4" = 6mm and 1/2" = 12 mm) gives less than 6% undershoot - each engineer needs to decide if that is fit for their purpose.
Better is
40 thou = 1 mm
100 thou (1/10") = 2,5 mm
1000 thou (1") = 25 mm
So 1/4" (250 thou) = 2,5 mm * 2,5 = 6,25 mm
as this gives less than 2% undershoot.
Hope I have not clouded the issue!!!
Nigel Armstrong
Lloyds Register
Independent Verification Body Surveyor
richay,
In my opinion Table 5-1B in API-650, 11th Edition, Addendum 1 is correct as shown.  This covers the case where a purchaser allows 6mm plate to be used where 1/4" would normally be shown.  Alternatively, it could have stayed at 1/4" and used a footnote similar to that shown in 5.6.1.1 (footnote 3).  Both work for me.
Joe Tank
