Does this material comply?
We have been asked to supply a lift lug for pipe made from CSA-G40.21-300W plate.
A note on the drawing states "All materials must comply with NACE MR01013"
Can anyone tell me if there is a conflict between the plate material and the NACE specification?
Brad
RE: Does this material comply?
Not if the plate is a P1 Group 1 or 2 material and not cold formed with greater than 5% outer fibre deformation.
Steve Jones
http://www.linkedin.com/pub/8/83b/b04
We are a structural shop so we aren't familiar with the ASME P numbers.
The plate noted above is the Canadian equivalent of 44W carbon steel plate. Does that fit into the P1 category?
There is no deformation in this case.
Brad
This is a Canadian grade of structural steel which is equivalent to ASTM A 36 structural steel. So, yes, this would be considered a P-No 1, Group 1 base material.
