Water Quality Storm
Water Quality Storm
Delaware's Department of Natural Resources & Environmental Control (DNREC) require the design of water quality structures to be able to manage the rate and volume of a 2" NRCS Type II rainfall event, up to a maximum of 1" of runoff.
Is it possible for HydroCAD to stop the routing procedure at a certain runoff depth? In my project, I have subcatchments that generate runoff depths that range from 0.5" to 1.6", for the 2" storm.
RE: Water Quality Storm
If you apply 2" of rainfall to all areas, what does DNREC want you to do when you reach the 1" runoff depth? Truncate the hydrograph at that time? And how is the peak flow determined under these circumstances?
Although HydroCAD can simulate any rainfall depth you select, there is now way to "stop the routing procedure at a certain depth". This is not a physically realistic situation, so it's hard to simulate.
Will the regulations allow you to design for 1" average runoff over the entire site?
For a discusion of first-inch calculations please see www.hydrocad.net/firstinch.htm
Peter Smart
HydroCAD Software
www.hydrocad.net
You may just need to do things the old fashion way. Delaware's regulation originally was simply the 1" of runoff. One has to determine the rainfall depth that would produce this amount of runoff.
It is rather untidy, but to optimize your design, one may need to create multiple models: one for subcatchments with 2" rainfall, and other models for those subcatchments that exceed the 1" runoff. In the latter models, one would adjust the rainfall to produce the desired volume.
Perhaps a wish list item for HydroCAD would be the ability to overide the rainfall depth on individual subcatchments. I do know of other hydrology packages with this ability.
Peter Smart
HydroCAD Software
www.hydrocad.net
It looks like breaking the model up for water quality analysis will be my best bet. Fortunately, it's rather easy.
