Preffered method For Wetting Breaker Aux Contacts in Relay monitoring
I have subsation design where three hydro plants are going to tie into the sub of one of hydro plants. Between the generators and the sub, there are a total of 7 breakers and 10 protection relays.
I am trying to simplify the wiring requirements from the relay digital inputs and the breaker auxillary contacts (relays monitoring state of breakers).
I wanted to know if common practice is to run both input channel leads back to the breaker aux contacts as in Wetting Method 2 attached or if its an acceptable practice to use Wetting Method 1 also attached.
Wetting Method 1 eases up wiring requirements on the relay as well as to and from the breakers. I would like to utilize this but want to hear from experience whether this is a poor method before proceeding.
Any thoughts on this appreciated, thank you.
R Proznick
R Proznick
RE: Preffered method For Wetting Breaker Aux Contacts in Relay monitoring
RP
In general, you need to be sure the wetting method used won't have a common mode of failure, where you could lose all your indication at the same time.
From my point of view ONLY methods 1.
"-" is common on the BI of relays
"+" is common on the aux contacts of CB's. DS's.
Izn't good practic disconnect "-" on the BI (binary/digital
inputs).
In additional, are less wiring.
Best Regards.
Slava
Isn;t critical, but is also some style of design
You connected "-" of relay power supply to "-" common of BI, but "+" you use frome other fuse/MCB, please use same "=/-" for the same loops, is safety.
Best Regards.
Slava
Look at the negative fuse below each relay in method 1 and trace the circuits back to the positive. You will wind up at both breaker positives and that is a disaster waiting to happen.
David, you are right, I dosen't put attention on the "+" to second relay BI.
Of course NO. I would recommend in this case use only ONE dedicated fuse/MCB for the BI.
Is safety and in case of some problem in the wiring, protective relays continue work, every one with dedicated power supply.
Best Regards.
Slava
Are these primary/backup relays? With either method you have shown, loss of either wetting voltage will result in both relays not sensing the breaker status correctly. In the attached diagram, loss of a single wetting voltage will only affect one relay.
I love the exchange of ideas and community on ENG tips.
Thanks to all,
RProznick
