display results
display results
display results
Dear members,
i'm a new patran/nastran user.
I modelled a 2D flat plate and a 3D solid plate attached on her top face.
I gave two differents materials.
I have two problems:
1) i have a valid solution only if the simulation is NON LINEAR STATIC. It's possible that there is no solutione for the LINEAR case?
2) During the post processing i can't display the stress fringe on the 2D elements, but only on the 3D elements.
There are problems or there is something to switch?
Thanks to everyone!
RE: display results
Would you post your bdf/dat file so I can run your model?
Onda
RE: display results
The 2D elements provided "layered" results, while the 3D elements provide "non-layered" results. In the "Results" menu select "layered" to view 2D elem results, and "non-layered" to see the 3D elem results.
mscpro
