CAD workstation deployment
I need help solving a hardware deployment problem for a client! I've got just over 1500sq ft of floor space + 300-400 sq ft max for IT data center. I've got to get 18-20 3D CAD operators, plus 4-5 admin & managers into this space. Workstation configuration will depend upon job function of each employee, but minimum configuration will be Core 2 Quad with 2GB RAM, NVIDIA 9800GT. Maximum configuration (at this point)will be Dual Quad Core Xeons, 16GB RAM, NVIDIA Quadro FX 1700 x 2 (quad monitor config).
For those of you out there who manage or operate in small or medium-sized office environments, how do you manage the PC real estate, noise, & heat issues in limited spaces? How do you plan for growth? Your help is appreciated!
RE: CAD workstation deployment
"How do you plan for growth? "
Are you a manager?
Cheers
Greg Locock
SIG:Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
you will not be able to manage noise much, other than noise reducing wall, ceiling and floor coverings. White noise generator might help. you won't have room for growth unless you can build a second level. Check with the fire marshall to see if you will be exceeding the max occupancy of the building...
- Steve
- Steve
