taptite screws: types,uses and maki
taptite screws: types,uses and making methods. kindly explain.
RE: taptite screws: types,uses and maki
There are a few different types of Taptite (R) threads, but all provide the same function: rolling mating threads during installation.  You can get more information from:
www.taptite.net
The manufacturing method is the exact same as machine screws: cut a blank from wire, forge the head/shank features, roll threads.
A couple additions to CoryPad's manufacturing methods.
Unlike "normal" machine screws, the "pre-threadroll" (as cold headed) shank diameter is not round, but has a cross section that will generate the desired "trilobular" thread shape/dimensions after thread roll.  These screws are also typically case hardened.
