Problems with nVidia Quadro & Dual Screens
We're mostly happy with our nVidia Quadro FX 1700 cards running SWX 2007 on Windows XP Professional. We run 2 monitors.
There is a problem that I can't resolve. The nView settings have an option to "Enable child window spanning across miltiple displays." Even if I uncheck that it's still enabled. I have to manually resize the child window each time
Has anyone else had this problem and resolved it?
I tried contacting nVidia but their customer service is non-existant.
RE: Problems with nVidia Quadro & Dual Screens
-handleman, CSWP (The new, easy test)
We used to be able to move & maximize a child window to a single monitor but we just got new computers with the latest nVidia drivers and that doesn't work any more.
I downloaded the older "approved" driver and that sorta fixed the problem (thanks handleman!).
Child windows still open across two displays but now I can click on the button to send them to one display. A minor annoyance that we can live with.
Sounds like you've got yours working at least as well as ours is. I like the nView hotkey to send windows between displays. I wish there was a hotkey to do the same thing with child windows. I ended up having to write a SW macro using Windows API to get that functionality.
